ECP.ParmInv
Description
Error checking has determined that an invalid parameter has been passed to the function. Example errors are unexpected NULL pointers or parameters out of range. As a result, the action performed may not have worked as intended.
Remedy
There is no known remedy. Inform engineering. Provide as much information as possible including config file, log file, and a description of actions that were being performed when log message was seen.
Severity
Critical
Message Text
Invalid Parameter %format%
Message Parameters
Name Type
format Printf
